Displays the configured number of IPv4 and IPv6 routes reserved in the Longest Prefix Match (LPM) hardware table.
| slot_num | For SummitStack only, this option displays the reservations for the specified slot. |
N/A.
The IPv4 Routes column in the command output shows whether IPv4 routes are stored in LPM tables.
To modify the configuration that this command displays, use the following command:
configure iproute reserved-entries [ num_routes_needed | maximum | default ] slot [all |slot_num]The following example displays the reserved space for IP routes:
# show iproute reserved-entries
# Reserved Routes Minimum #
Slot Type IPv4 (or IPv6) IPv4 Hosts
1 5720-24MXW 20432 ( 10216) [default] 4112
Maximum supported # IPv4 (or IPv6) Reserved Routes:
5320 16-port, 5320 24-port 8160 ( 4080)
5320 48-port, 5420F, 5420M 12256 ( 6128)
5520 16352 ( 8176)
5720MW 16352 ( 8176)
5720MXW 24544 ( 12272)
Note: IPv4 Hosts can occupy unused HW Route table space,
unless # Reserved Routes is "maximum".
